anderso8623
- May 25, 2012
- 388
When shifting from either neutral to forward, neutral to reverse, or back to neutral from either direction; I have difficulty. I must essentially slam it into forward, reverse or neutral, causing the RPMs to spike.
The shifter is very stiff when in gear. I pop it into the neutral position and rev it and the slide is smooth and effortless.
The shifter is a single handle shifter with neutral between forward and reverse. When in neutral, you can pull the handle out to rev it either forward or reverse. Neutral is very difficult to find as I often over shoot it due to the slamming into and out of gear.
Following the shift cable back, I have a shift box. The cable running from the shifter ends in this box and is connected to a "pulley-like" set up. From the box to the lower unit is the same type of cable. The two cables consist of metal cables inside the actual cable. At the ends that go into this box, there is cylinder like connectors to connect the cables to the pulley system.
I am not sure what is causing this stiffness or if it natural for an older design such as this one. I have asked around about the cause and people have suggested a tension screw in the shifter; when I asked the local shop they said there was none in this model.
I will try to post pictures later on to help explain but I do not get home till 10:30 or so.
Thank you
Jason
Thank you
Jason
