So I think I need to replace my gimbal ring as it's pretty loose at the steering shaft. I've read in a few spots online that yoyu can just tighten the u-bolt at the steering shaft and be fine but wanted to check here first. Isn't the u-bolt spec'ed to be torqued at a certain amount and tightening it will just be cause for failure? A new gimbal ring is $600!!! I fear going with used would just lead me to another loose steering condition in the not too distant future... I also fear no other options. HELP!
