Hello,
I have a quick question for somebody to help me out with. I was told by a merc mechanic that at some point I need to have the motor mounts replaced and that is causing the engine to vibrate/ shake. When running you can see it moving slightly. Not sure exactly how to explain it but the engine isnt still. Is that the sign of a broken mount? Wanted to make sure he wasnt pulling my leg. Is there a good way to tell if it is the lower or upper mounts? Or both.
Can the boat be used safely until I have the time/funds to address if it is the mounts. Engine runs good otherwise.
thanks
thanks
