Re: 1992 Johnson 70 horsepower
Got flywheel to come off.now I may have another problem.on the first attempt to get the flywheel off I used the bolts that came with my puller and striped 1 of the bolts so I went and got grade 8 bolts and a tap to go through all the threads on flywheel because the they were a little rough.after I got the flywheel off I noticed I had tapped into the trigger about an 1/8.is this going to keep it from working properly will I have to replace trigger as well?
