I am new to the forum, I am having trouble locating the information I need to get our boat up and running. I apologize if this information has already been posted.
We currently have an 1986 Seaswirl with a Cobra outdrive. However the engine was bad and it was removed.
With the cobra unit, the flywheel and engine coupler have the bolt pattern for a one piece rear main seal. My question is,
will an older omc, non cobra engine coupler work with the cobra unit?? Do they have the same spline and length?
I already have a good engine, however is is an older engine and has the two piece rear main seal bolt pattern.
Thank you for your response
Rob
Rob
