I replaced my water pump last spring with a kit. I followed the manuals instructions and things seem to be pretty good when it is hooked up to the hose. However I have searched everywhere and cannot find a solid answer on this.
The water guide tube seems to fit tight in the top of the water pump housing just fine. However the water guide tube that slides over the copper tube in the upper unit does not have a seal, o-ring or anything. If there supposed to be a rubber seal of some kind that goes on the copper pipe to create a tight seal?
All of the diagrams I have looked at do not show one but I cannot image it is sealed without one.
If there is a seal, gasket, can someone tell me the name or part number.
As I said everything seems to be running fine, but when I split the upper and lower, there was a bunch of water sitting in the reservoir where the lower shift shaft is when it was just running on the hose/muffs, so I think the water pump is leaking at the top of the guide tube. maybe this is normal and does not matter it is leaks, but I just wanted to check and make sure I was not missing something.
