I have to reroute and make a new pump to carb line for my 5.7 mercruiser. I planned on using epoxy coated 3/8 steel line from auto parts store and bending to fit. I found a Sierra part number for a flexible fuel hose with the correct flare ends on it as well. Any issues I should know about either way, seems pretty straight forward unless im missing something. The flex is more expensive but would be quicker, if its close to the righ tlength
Is the original merc line steel or aluminum. Its shiny and at first i thought it might be stainless steel, but it doesnt seem heavy enough. Its non magnetic so its not regular steel.
