Greetings all,
I've recently acquired a boat with a circa 1975-76 Chrysler 75HP....it's going to need some work, but currently trying to reassemble the tilt/trim valve body/pump that was included "loose" in a bag. One of the ports had the threads stripped out and I was able to repair that.
This is the style of valve body that contains clips in the sides (I believe the original Prestolite style). On this particular style, there is no adjustable pressure setting...they appear fixed. However, the two springs included are of different stiffness and I'm looking for guidance on which side of the valve body should use the stiffer of the 2 springs.
Image courtesy RRitt rebuild listing.
Thanks for any help,
-JeffR
-JeffR
