Re: Stuck Flywheel
I had read about the possible bearing and thrust washer damage, and pray that me being as cautious as possible with my "rapping" of the puller bolt did not damage anything. I used grade 8 bolts in the original sized 1/4" 20 flywheel holes and there was so much pressure on the puller that each time a bolt broke it shot feet into the air across the shop LOL
After I drilled the holes out to 5/16" 18 holes the pressure was so great that I actually wrapped the puller with a fender cover because I got so nervous about where the pieces would fly and what damage would be caused if something broke. I used an Ingersoll Rand 1000 lb. impact and still almost ran out of impact before it finally let loose, and then only after rapping the flywheel around the outer edge. When you have one with defective electronics and the motor wont run, what choice do you have? In my case, the motor ran fine, I just wanted electric start, so I guess I could have sold it and found another one that already had electric start. You know how it is, you start on something and it almost becomes a quest to see it through. Crazy to be on there that tight, but I understand if it is not then you risk shearing the key and spinning the flywheel and possibly damaging the crank. Anyway, I did run the motor after this and it sounded fine, but only time will tell if the bearing rollers have flat spots, hopefully not.
