Re: Adding a temperature alarm
Old standard technology, the issue with gauges is that unless you find a proper spot to install probe to read fast overheats and trigger the alarm are near useless. Could work fine If yo have a slow overheat due to semi clogged water passages, 2 stroke oil issues mix, oil pump failure, whatever, and that's at slow speed.
Worst scenarion, if you were runing at 3/4 to wot and a plastic sheet, paper even a banana peel blocks your lower tail water intalkes, temp will rise so high fast that sensor will not have time to trigger the alarm and protect engine. How about installing a thermo fuse, like the ones that protects appliances that produces heat as in hair dryers, house irons, the small ones that blow open when a certain temp has been reached and shutts down whatever it was attached to. Are available in different temp ranges, a matter to know which temp will suit best your engine.
It's like runing your car on a highway at speed and blowing you radiator, as there's no inmediate indication of this problem, while gauge detects this as an overheat, probably you're are done with your engine. Personally have fried 3 portables due to water intake blockages at speed.
Happy Boating
