Im not getting any spark im assuming my powerpack is bad?any info would b great.
D dieselcat Petty Officer 1st Class Joined Feb 1, 2009 Messages 351 Jun 1, 2013 #1 Im not getting any spark im assuming my powerpack is bad?any info would b great.
B boobie Supreme Mariner Joined Nov 5, 2009 Messages 20,826 Jun 1, 2013 #2 Re: 1992 johnson 70 hp Disconnect the black/yellow wire from the pack and then re-test it.
D dieselcat Petty Officer 1st Class Joined Feb 1, 2009 Messages 351 Jun 1, 2013 #3 Re: 1992 johnson 70 hp OK,not exactly sure what kinda test your referring to?just a simple turn the motor over to see if it gets spark or with a multi meter?if multi meter test which setting do I use?
W Will Bark Lieutenant Joined Aug 1, 2010 Messages 1,470 Jun 2, 2013 #4 Re: 1992 johnson 70 hp See if it starts with black/yellow disconnected.
Chinewalker Fleet Admiral Joined Aug 19, 2001 Messages 8,902 Jun 2, 2013 #5 Re: 1992 johnson 70 hp Black yellow wire is kill circuit. Trying to start with it disconnected can eliminate kill as an issue. Check ground wire for connection snd corrosion on pack, too.
