Ran then sputtered at the dock and now no spark. One thing I noticed the binnacle doesn't have the dead man switch hooked up. One black yellow wire goes from key switch through main harness to motor. The other one is inside the binnacle about two inches long and is going to nothing. There is a whole where the switch should be. The motor ran without the kill switch so im not sure that's it. Looking to get the ohms test for the ignition components on the motor. Cd pack Coil Stator trigger. Anyone able to help?
