minuteman62-64
- Apr 12, 2011
- 1,350
Looking at increasingly stringent regulations w/regard to dry weather water runoff from property. I'm thinking about the discharge from flushing the salt from my outboard, and wondering if there is a way to capture the water.
My biggest source of water from flushing is the leakage around the muffs. I tried the flush port, but all that does is push water out through the water intakes (didn't try cranking the flow up to the point where water came out the discharge ports).
So, I'm wondering, if I pull the thermostat (piece of cake with my motor) and squirt water/Salt Away through the thermostat housing till it comes out the tell tale and the exhaust discharge point, will that do an adequate flushing job? The volume resulting from even 5-10 minutes of flushing will be easy to control.
If that won't work, any other ideas?
