I have a 1987 Bayliner Trophy with a 5.7 OMC (Chevy) I am losing power steering fluid, I can't locate the source of the leak is it possible for the cooler to be leaking and pumping the fluid overboard?
Usually (not always) when a cooler has a leak, It will leak water into the oil. Since the water pressure is greater than the oil that is flowing through the cooler.
