  #1
Old August 14th, 2005, 06:02 PM
thomas_e102 thomas_e102 is offline
Default Painting aluminum fishing boat
I have a 1994 Alumacraft tiller that the old owner let bang up on the docks. The sides are in pretty bad shape. I want to paint the sides only but I am not sure how or what to do.
  #2
Old August 14th, 2005, 07:07 PM
Omega-1 Omega-1 is offline
Default Re: Painting aluminum fishing boat
Thomas_e102I assume that the Alumacraft tiller is made of wood. However, no matter what the basic material is made of, preparation prior to paining is essential for a good and lasting outcome. Here are some steps which you can use to accomplish a lasting and pleasing paint job:1. If the surface is very rough and weathered, take a 60 grit sand paper and sand all the loose junk off the surface, then finish sanding with a 120 grit sand paper until the surface is clean and smooth.2. If there are any surface defects to fill in, take some filler epoxy such as Marine Tex, mix according to directions, fill in all cracks, holes and crevices. Let the filler set overnight, then sand it smooth.3. Select a marine primer paint to paint the tiller and let this cure until dry, perhaps 24 to 48 hrs.4. Select a marine grade paint suitable for wet surfaces. Paint over the primer coat one coat, let dry then lightly sand with 200 grit sandpaper. Wipe clean and apply a final finish coat and let dry for at least 3 days before exposing the tiller to water. Your paint dealer will assist you in selecting a proper marine grade paint for the basic material of the tiller.Good luck, have fun, be safe.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
help painting an aluminum boat jwilkey84 Boat Restoration and Building 7 March 17th, 2006 06:45 AM
Aluminum Boat painting ? g6ips3y Boat Topics and Questions (not engine topics) 1 August 4th, 2005 02:01 PM
painting my aluminum boat jscotty Boat Topics and Questions (not engine topics) 2 July 21st, 2004 08:22 AM
Painting aluminum boat Tackle Box Boat Topics and Questions (not engine topics) 5 August 13th, 2003 07:55 AM
Painting an Aluminum Boat springbok Boat Restoration and Building 2 August 12th, 2003 08:26 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
