  #1
Old August 14th, 2005, 06:05 AM
cassfam7 cassfam7 is offline
Default DreamBoat Mid 70's 16' fiberglass center console
This boat is made by DreamBoat. When I baught it I was told that the ribbing had all been repaired. You can see evidence of the repair. I have two questions related to the boat. First it came with a non-functional outboard (85hp). It is rated for 80hp. what are my best options for repowering the skif? What hp should I be looking at for performance? Next, some fiberglass repair has been done to the bottom as well. It's all solid, what steps do I take to paint the hull and how do I repair superfisial cracks in the decking all around? Thanks for the help. It's my sons and my first boat. Cass
  #2
Old August 14th, 2005, 01:22 PM
prockvoan prockvoan is offline
Default Re: DreamBoat Mid 70's 16' fiberglass center console
First off,a 70's boat with a 85hp 70's motor,you have work to do.Motors that were rated back in the 70's was rated at the cid,years later,around the mid 80's,the makers started rating the hp at the prop.Big difference!A over hp rated motor installed on a older boat is one of those things that should not be done,being it is ya'lls first boat.Some states that would be breaking the law.Painting the boat.You must dewax it,sand it,prime it and then paint it.
  #3
Old August 14th, 2005, 01:45 PM
OK, So if the my boat is rated for 80hp in the mid 70's, what would be the equivalent modern hp be? What would a 1968 85hp evinrude be equal to today? I don't mind going lower on the hp. I would just like to get around, and maybe pull a kid in a tube.
  #4
Old August 16th, 2005, 02:52 PM
JasonJ's Avatar
JasonJ JasonJ is offline
The difference between prop and crank ratings depends on the individual motor, and in some the difference isn't that great. 10% if that. One thing to remember, a newer motor weighs a bunch more, so it may have a few more ponies, but that is offset by the additional weight. I can guarantee my 270 pound 125 horse 69 merc would be faster than a new 125 horse at twice the weight. That 68 85 horse would need to be replaced with something close to 100 horse to offset the increased weight if you are looking for similar performance. Since you don't know what the performance is, you will have to guess. Also, you need to look at your total weight capacity. If you stick a new heavy motor on that is the same power, your load carrying ability will drop due to the increased weight. The hull design plays a part in safety and handling as well. If it is a flat hull skiff, it will be less stable in hard turns and rough water than one with any kind of V (deadrise) to it. I would try to get the most power you can afford that allows a good compromise between safety, economy, capacity, and fun factor. Good luck....
__________________
Project Skanky Beast http://70silverline.250free.com/Skankybeast.html
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
20' center console rubberduck Wellcraft Boats 4 April 19th, 2007 05:35 PM
New Boat: Center Console , Walkaround, or Dual Console PAkev Boat Topics and Questions (not engine topics) 17 April 2nd, 2006 08:14 AM
Center Console - What is the best Ply? Knightgang Boat Restoration and Building 8 November 12th, 2003 06:18 PM
my little 16 ft center console crab bait Boat Topics and Questions (not engine topics) 34 July 17th, 2002 04:04 PM
19'-21' center console gatorperk Boat Topics and Questions (not engine topics) 6 February 15th, 2002 01:53 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
