Or I believe it's ignition.
Evinrude 70773S 1977 70 HP
Coming back a cross the lake last weekend just cruising at about 3K the motor suddenly falls off. I mean suddenly boom RPMS drop to 2K and the tone of the engine changes. Full throttle only nets 2900 ish RPM when it was getting me 4200ish. Ran it like that for a bit and then as suddenly as it fell off full power came back. This, to me, says I lost a cylinder. Motor did this a couple more times, with a varying duration, on the 20 minute trip back.
On the muffs last night motor ran fine. Have spark on all 3 cylinders as check with a timing light. Went through the ohm testing of the trigger and stator is presented in the Clymer and all is ok. Coils all ohm out the same but that may mean little as the resistance is very low at 2 ohms.
Problem does not seem to be heat related as the motor was stone cold before starting out and we had been out cruising for much longer earlier in the day with no issues.
Any clues? Is there voltage checks I can do? I can't seem to find tests for this year motor.
