IanFS
- Apr 21, 2009
- 188
I'd forgotten about this until I started to recently re-commision my '88 Sea Ray Seville 4.3L Alpha One.
I had replaced the elbows, exhausts, flappers (with the new style), upper stern drive seals, water pump impeller and housing etc. Upper housing seals, gimbal bearing, drive bellows, exhaust bellows, water hose, shift bellows.
However after a great outing last year we pulled back into harbour and at moorings there was a small oil slick whilst the engine was runiing.
I read an article from hear that said it could be from the trim pipes, which I am yet to investigate. However it was almost as if there was some oil coming out of the engine, which from my motor trade background seems odd. Unless there is some sort way in which a marine engine could displace oil via the exhaust.
It could be from the lower gear housing seals, so I drained the stern drive and checked the lube. It seemed ok, fairly clear, so I tested some of it by adding a little water. Then some new lube to check the difference. There was a little difference but not the same as if there was a lot of water adding to it.
Would anyone be able to advise the hotspots for this leakage so I can investigate fully?
Kind regards
English Mariner
Kind regards
English Mariner
