connerdean
- May 28, 2013
- 9
Hello,
I have a 4.3 GL PWTR engine (4110178507) (3862941) with a SX-M 1.66 outdrive (4112046634) thats not sucking in water from the outdrive. I bypassed the hoses from the outdrive and ran a hose from a bucket full of water directly the intake of the water pump and it working fine. I then checked each hose using the same method back to the transome and again the pumps working. Pulled the outdrive (needed to grease the u joints anyway) and connected water hose to the hose off the mounting pivot and all worked fine. I need help understanding how the water is drawn from the outdrive. Drawing I've looked at show a hose in the lower end of the drive but no physical connection to the hose where the outdrive comes off. I assume the small rubber gasket forms the seal too the outdrive but its unclear how this works. could I be losing suction due to a bad gasket ? anyway any help would be greatly appreciated.
Thanks
Tom
Thanks
Tom
