Spvracing01
- May 30, 2013
- 6
I have a 1988 20hp merc that will not get up and go the bulb get hard after about 5 pumps and then it starts to loose pressure and go soft it's a brand new line with bulb the fitting on the tank is also new tank isn't I put a fuel filter in because there wasn't one before and I notice when I prime the bulb it get hard fuel will slowly go bac down into the tank I've taken the carb off twice cleaned once along with fuel filter then the second time I replaced all the gaskets there is no leaks I can see in any lines that gas is escaping or air coming in. The motor starts right up and at wot it only goes about 5mph will not plain off and I have to keep pumping the primer or it does out. I have gotten the raft to plain off and go about 3 times but only for a couple seconds randomly then motor shuts off again it barely ever happens. HELP
