Bimini top help
halljb2
I have an 08 q6 and I have had trouble with the Bimini top frame coming loose frame the little mounts that fit in the boat. I was wondering if anyone else has had this problem and if so, how did you fix it. Thanks
BiggerDee
Re: Bimini top help
The little clips might be bad. I had one that got stuck on my 2011 Q7ssi about a month after I got it. I couldn't remove the bar at all because although the clip button would move, it wouldn't move up enough to release. The dealer had to replace it. He said that they occasionally fail in ways like that, although it wasn't frequent. The spring in yours may be weak/broken, preventing the licking button (if they are like mine in design) from springing down and locking them. Just a thought.
