greg82255
- Oct 26, 2009
- 781
Hello,
I have a recently rebuilt 383 stroker mated with a 1986 gen 1 alpha drive - same block as the original 5.7 from the same year. It was running fine when I winterized it last season, but I started it up for the first time last week and realized that no water was flowing through the engine. I didn't see anything coming out the exhaust and there wasn't anything being pumped in from the muffs. I instantly thought that the impeller was gone and went to replace it today, but it was 100% intact, as were all the other parts of the water pump. I replaced them anyways, as I was going to do it for standard maintenance, but now I am wondering what else could be stopping the water flow. After running the motor, I took one of the drain screws out of the block, and no water came out. Any guesses where to start? I did remove the drive for the winter. It seems like there is no water getting to the engine at all. Maybe the drive needs to come back off and check for something inside a hose? Any suggestions that could be done before pulling the drive would be appreciated.
