fatfishfan
- May 19, 2013
- 39
I didnt know which forum to put this in but i am replacing the wood under the seat cushions, what do you guys use to remove mold/mildew on the vinyl?
mine are pretty funky, think bleach and water is the way to go? If so how much should I dilute it? Some of them are coming off completely so I could actually soak them, for the once that arent coming off should i just spray them and let it sit for a while?
I just use a few caps of bleach diluted in a spray bottle of water. I spray all the areas I'm going to clean and by the time I get back to where I started the bleach has really started to work. You just have to wipe it off at that point.
The guy with 12,000 posts recommends a product above. It probably works
