Re: Electrical Drain
...I believe I found the issue. ... The 2 with quick connects I believe we're hooked up backwards. I switched them around and my electrical drain went from 2.7 amps down to .005 amps. As long as it charges it should be good to go, if not means the alt is bad. I am assuming the wires were hooked up backwards since I know this engine was taken out by the marina where I bought it. Believe me this is not the only mistake they made. I am hoping this is all that I run in to...
... Now my key wont turn the boat off but the key does turn on the gauges and start the boat. ...Maybe there is a diode shorted in the alt after all or maybe the short is in my key ignition module. Either way it is better the way it is right now as its not draining my boat electric and I still have the extra kill switch to kill the engine. To be more specific, now when I turn my key off, all the gauges stop working on the dash but the engine still runs until I turn off the separate kill switch.
There is to much "I Believe" going on here and not enough "I Know, and can prove".
What indicated to you that the wires were reverse? Just a Hunch?
What wires were they?
Is sounds like they are NOW Backwards.
If the Engine stays running, the ignition is still powered. You still have a drain.
If the motor happens to come to a stop with the points open, you will not see it.
If it stops with the points closed, the Ignition coil will remain energized and drain the battery.
Do not make assumptions that are not substantiated.
After you switched two "unidentified" wires at the Alternator, The ignition switch would not shut off the engine.
This indicated the wires were not wrong to begin with, NOT that the Ignition switch "Coincidently" went bad.
Put the wires back to where they were while you can still remember.
Trouble shoot the problem properly or you will be creating a wiring disaster that no one will be able to figure out.
