Greetings,
I have a 1987 Black Max 150 HP with the Integral trim system. The manual calls for Type A or Type AF ATF. The possible problem is that I put Castrol Type F in it instead before realizing my possible mistake? It has worked though, just don't want to mess up any O-rings or seals if the Type F should not be in there?
Is the Type F ATF suitable (I'm not sure of the differences?) as it's already in the system? If not, is Type AF the same thing as Dexron II/III?
If I need to change it, what's the best way to get the old stuff out?
Thanks for help!
Thanks for help!
