Hello I am considering buying a 1997 Mercury 2.0 150hp carbureted 2 stroke. I ran a compression test and the 4 top cylinders read 90lbs and the 2 bottom cylinders read 80lbs. Are these readings acceptable or should they be higher and if so what should they be?
