Had the boat pulled in February to check/change bellows, check engine alignment, and replace gimbal bearings if required. Dealer did all that and showed me the trim sending unit puck with the wires almost pulled out and told me that should be replaced also.
Due to the colder weather we have only been out about five times since dealer repairs. I always check engine compartment before leaving dock and noticed the gear lube reservoir is low. I add VP gear lube. Next day low again, add more gear lube. I have added about a quart so far. It should only hold a little over two quarts so adding this much seems excessive after a gear lube oil change.
Where is the lube going?
No lube in the bilge, no lube in the water. Even trimmed drive up and ran it forward/reverse several times then waited for lube to show up. No lube in water.
Dealer says it might be the "Y" coupling that connects reservoir hose to stern drive. Claims they go bad all the time. If no oil in bilge or water then the "extra" lube is in the bellows.
Anyone ever heard of this or is this something that might have happened during the other repairs? Don't really want to pay for their mistake if I can help it.
