Monkeyslap79
- May 27, 2013
- 6
I got a 1973 mercury 850 thunderbolt, I bought it with a fuel leak, it always worked, I found the fuel leak was at, ( on part pic ) Fuel pump assembly, there was a hole on the gasket for the fuel pump assembly and the gasket behind that that goes to the looks like pistons, I replaced them, now then I pump the gas ball it gets full and tightens up, but the boat won't start up, put old holy gasket in it starts but has gas leak. I thought it would be fuel lines was the problem, so I check each hose to the Carb, all are good, so without the bad gasket it's not getting the gas to start, any ideas?
