jensoqvist
- May 27, 2013
- 1
Hi,
This motor have been working perfect to now. This season its not reliable, sometimes it work perfect and sometimes it just dies when I throttle up. Even dies at default when I start it sometimes. Its like this. I start it, it works fine to some RPM, like middle range, then above that it sounds wierd and there is no more power even if I pull the gas further more. Then when I stop for some fishing and when I start it again it works fine again, then when I have been going for 5 min at full gas its dying again.
I have oil in the tank, I know that it will turn down the RPM automatically when there is low oil level, but this is not that. It?s seems like its not getting the right mixture of fuel and air. Maybe there is some kind of filter I should clean? What do you think guys? Give me some help where to begin with the trubleshooting
