1979 Quartermasters
- May 30, 2009
- 505
Good morning people:
I have been chasing this oil leak for some time. I pulled the engine this winter and changed the oil pan gasket, speedi-sleeve and seal in the timing cover and valve cover gaskets. The timing cover looks minty. When I had the engine out I checked the rear main seal, and there was no evidence it had been leaking.
I did a head gasket last summer, but it was leaking before that.
The leak doesn't seem to be getting any worse.
I notice the oil dripping off the timing cover, the side of the block is oily and when I took the starter in to be repaired the tec said it was full of oil. Yesterday I noticed a small puddle of oil on the intake right at the back of the engine. So now I'm thinking maybe the distributor seal is leaking.
I have a new gasket coming and I'm wondering if I should use Permatex with that gasket, the stuff I used with the intake.
Any other ideas where this oil is coming from?.....
Ken
Ken
