donwonnc
- Apr 18, 2013
- 19
I took my buddy hubs off to clean and inspect. I don't understand what I found. No spring, snap ring and no plate to push the grease in. The grease fitting is attached to the inside end of the axle? I found the name E Z Lube on the dust, black rubber plug. There is no cotter pin, rather, there is a metal tab bent to keep the axle nut from turning, but it shur seems lame compared to a cotter pin. Do I have gravity fed buddy hubs, everything is as it should be but it is old school? If anyone can tell me what I have and what I should have, I would be grateful.
