ok all I need a bit of advise I rebuilt the seapump in my gen one a couple weeks ago but just got to test it out today I plan to put it on the muffs and look at it again tomorrow to make sure I will also get out my waterproof camera and take another pic while running. What happened is this when i put it on the muffs this morning to check everything before heading to the ramp I noticed that appeared to be a leak around the nut infront of the shift shaft here is pick of where I am talking about now since I had it on the muffs I took note of this but didn't think much since water gets everywhere on muffs. ater seeing the pump was working ok i took her to the ramp and put in when i pulled her out i noticed some oild in the water and looked at the outdrive after after retrailering and found oild around the bolt in the above pic I am trying to figure if I missed a seal when reassembling the drive as. hope this makes sense and some one can throw a suggestion at me on what to check.
Thanks,
Yonu
Thanks,
Yonu
