Re: One plug sparking
You made a good start on the troubleshooting. As you mentioned, switching some easy parts vs spending is good. I feel you are in the right area but good parts to specs and setting to specs should get some results.
1. Did you switch condensers? Did you find factory spec parts that you changed?
2. Did you run a continuity test on your points (to know they were making contact?
3. Were you sure on the method and spec of setting the points?
4. Could the air gap on the coil be adjusted or one set position (coil to fly space)?
Uploading Pics:
1. Sel reply and Go Advanced.
2. In the adv menu bar you will see a paper clip, click it 1-2 times to allow attaching Pics.
3. With no past pics to drag to the bottom window, sel add files (top right) and Sel files.
4. I?ll suggest the files have to be smaller than 1 meg in Win Properties.
5. Sel files from your saved location on your comp, up to 5 at once holding ctrl key.
6. Sel up-load, sel done, view your preview and submit when satisfied.
7. Once you see the Advance format you will catch on quick. I hope this is enough to start.
