First post but have have been doing tons of research and maintenance on this boat before I decided to post here.
The back story is I bought a 1999 glastron with volvo penta 3.0 on cl with 190 hour. The owner stated it head a blown head gasket, it was overheating and that there was water in the oil. I Got it and removed thehead and had it magnufluxed, decked and had the valves reseated. Put all new seals including thermostat, head gasket, exhaust gasket and a few other small seals and gaskets. Rebuilt the carb and put all new seals in it as well. The block had perfect compression with no signs of cracks and did a pressure test on it and it was fine. Also went ahead and replaced the gimbal bearing, Jack shaft seal, exhaust bellow, gimbal bellow and changed lower unit oil.
That being said I changed the oil with new oil filter about 5 times to try and flush all the old oil out until I got good oil coming out after change. I would run it with muffs about 15-20 minutes on land everytime. The last oil change oil came out perfect. So put a new wix filter on it and filled it with higher quality oil. Ran it with muffs for about 20 minutes and the oil was perfect on the dipstick. I was satisfied. Forward and reverse on muffs was very smooth so I was satisfied for my next test.
Took it to the lake to go camping and before launching i ran it on muffs again for about 20 minutes and checked the oil again and perfect on the stick. Also installed a secondary water temp Guage next to the motor in the back just to make sure I was not over heating. Block after 20 minutes on muffs got up to 150 and stayed. Water temp on the cluster showed 175 but itsit's sending unit is on the thermostat. So no signs of overheating.
Launched the boat and ran it for about 10 minutes on the lake checking everything I could. Boat ran spectacular. Idled perfect, no signs of over heating, great top end and acceleration. Got it back on the trailer checked the oil and hazy oil. Didn't think much of it so I took it back to the campsite thinking it would be ok for when the family came out to tube all day the next day. Woke up the next day to prepare the boat once again and when I checked the oil it was milky just like when I first changed it before the head gasket install.
I am stumped. No signs of water intrusion on land even when ran hard on muffs and the block getting to fully warm temperature. The oil was questionable after launch but was way worse in the morning even after the boat was not ran or touched over night. The boat is completely fine and you wouldn't even know there was a problem unless you checked the oil.
So my question is where is my water coming from? Why is it find on land but in the lake it's not? And why did the oil get worse after sitting not being touched overnight? Please please please help.
