Re: heat exchanger
It's not pressed in or anything. Just pull it out. I used a pipe near the inside size of the metal sleeve and used it to help wiggle free the sleeve.
When you put it back together, it tightens down when you bolt everything up, no sealant needed. Replace all four o-rings though.
