My back truck tire is on the water already. I think the problem is I am too far in the water and the trailer is flexing cause I crank all the way to the stairs. The boat sits pretty high on the trailer. I think the slide will allow me to load like our ski boat. Get three quarter trailer under the water and crank it up.
The issue is I submerge the trailer bunks completely and crank the all the way til the front is touching the stairs. When I pull it out of the water there is about 2-3 inches of gap between the front of the boat and stairs. I am thinking if I install bunk slides I will be able to winch the boat up and not be so deep. I really don't know what is going on and I was really frustrated that once I pulled out of the water completely the boat was not sitting on the trailer correctly.
I have this exact situation. It's because when you winch it up to the stops, the back of the toons are probably still a foot off the bunk. When you pull it out, the boat settles on the bunks, and that "pivots" it away from the bow stop. Bunk slicks really help with that last 2 to 3 inches, after you're out of the water. I also have a 2" ratchet strap, that I take from the bottom of the middle toon, FORWARD around a cross-member, and back to the bottom of the middle toon. I use this to pull the boat forward to the bow stop - because if i try to do it with the bow winch, the bow stop just FLEXES back!!!
What sort of gides to you have
I hope that does the trick. Do you have any pics of you ratchet setup?
