thundercraft1
- May 20, 2013
- 6
I just bought a boat for my first time and it has a 1975 evinrude 70hp on it. The tilt cylinder has a bit of fluid comming out of the top not alot just enough to see its a leak. I bought a seal kit to fix the problem but found a new problem. The pin that goes through the top of the trim cylinder rod that attaches to the motor is siezed i cant get it to budge had a air hammer on it but wouldnt move. wonderfull invention to put a steel pin in an aluminum bracket. any ideas how i can remove this pin.
