JFK boating
- May 24, 2013
- 7
I think it's a 1963 gale sovereign 40hp ran rough at idle but once throttled she took off (first day I bought it) then died checked for spark only lower cylinder. New plugs still nothing pulled flywheel and all parts look new and had new crimp eyelets (indicates recent installation?) set points to .020 trimmed wires on coil end re installed and had nice spark on upper cylinder and weak on lower. Tried to start anyway no start rechecked spark and nothing. This is with the two black wires from the coils disconnected.(kill switch wires I think? One to the key and one ground?) One black wired has a knife/s connector and the other has an eyelet. Does the eyelet go to terminal on the left hand side of the motor looking from rear of boat. That terminal is on a vacum sensor thing. Also there is a white wire coming from a switch block on top running off the timing plate to that vacum sensor. What is that switch button for? Also the round plastic part of one coil is a little loose slides on the metal plates? Points are new by the looks of them condensors and coils all look fresh.
