Well I had the boat out the other day and had other issues with my f-n-r linkage. The boat ran well and we ran it out of gas. Here is what I'm now noticing when I return the throttle to idle the linkage doesn't go back to idle. More specifically it has to do with the advance rod that runs under the flywheel. It's not frozen it does advance all the way up however it fails to return all the way which keeps my idle screw about 3/4" off the stop. Any ideas? Is this common for something to break under there causing it to stick? It did return all the way prior to my last lake trip. I didn't pick up on it out there cause I had the gear shift cable disconnected and had manually placed it in forward due to my other issue. I would think if something got loose under the flywheel I would have spark issues.
Any guess's? Thanks Mitch
Also I thought maybe it got turned out so now it was advanced to much but I don't think that's the case as it ran fine and it doesn't appear like I can just rotate that timing advance rod. It's got the lock screw snugged down.
