Re: Spark plug gap question
The engines come with them from GM, but GM only builds fuel injected engines, it's Volvo that turns them to carbed engines. And the carbed engines do not require that "Extra" plug. Use them if you want, but do not mess with the gap. Or use the less expensive plug as recommended by Volvo (although not the champion) and the engine will run just the same.
