Hey fellas I've been chasing this problem for a while now. and haven't had any luck yet. The Boat has a 1990 OMC 5.0. The issue is when I go to WOT the boat stumbles and spudders. sometimes it will run great and then some times the problem pops up. it pops up more than runs great .It also runs awesome on the ear muffs in the drive way purrs like a kitten. I've went through the carb"2 barrel" Holly with a rebuild kit and even after the rebuild I've went back to make sure the jets were clean. I've also replaced the fuel filter and ignition coil and spark plugs. I'm kind of stumped I'm trying to get the boat ready for this weekend but not all that excited with this issue. I've read that it might be the pick up line being clogged in the gas tank. This might explain why it took about 3-4 min of turning over the motor to prime the new fuel filter and to get the motor fired up. or it might be electrical in the dis cap. any thoughts on this?
Also what is the normal operating RPM for a OMC 5.0 with a Cobra outdrive? all I can get out of it is around 32-3400 rpm and maybe 35-40MPH does this sound about right?
Thanks in advance! hopefully I will get this all knocked out and working properly.
