1986 Mercruiser 260 5.7
Here is a weird one. Last year before I wrapped my boat I changed the oil and noticed some oil on the back of one of the heads. I figured it to be a bad valve cover gasket so I pulled the valve cover to find out the valve cover was rotted. I hade two small block chevy valve covers so I got new gaskets and swapped them out. That's all I did besides draining the engine of water. Just the oil change, valve cover swap, took batteries out, drained the water and covered it up. No other changes since last year when it was running fine.
This year I have taken the boat out twice and only when in gear and under 1500 RPM's (Trolling through a no wake) I every so often hear a puff of air come from the engine compartment and the engine stumbles for a brief second. Other than that, it runs smooth and strong, no other problems. All tuned up and happy. Idelling (not in gear) fine, motoring over 1500 RPM's fine. Just trolling, every about 1 to 1-1/2 minutes I hear a puff of air and the engine stumbles for a very quick second.
The breather tubes appear hooked up correctly and are obstruction free.
Weird right?
I am wondering if at low RPM crankcase pressure is building up in the valve covers and overcoming the breather tubes and blowing out through the valve cover gasket every once in a while causing the puff sound, I mean I guess a quick drop in crankcase pressure would cause a slight stumble right?
I think I will tighten the valve covers next time I take it out and see if it goes away.
I find it very odd, I thought I would post to see if anyone else ever heard of anything similar???
Weird right?
