lstewartff
- Mar 6, 2013
- 53
ok I hope i can explain this right. I took my boat to a mechanic to fix carbs and change out the water pump. He said he ran the motor with no problems. I took it to the lake to test it and when I tried to start it it acted like the battery was going dead so I charged the battery, and the same thing happened. So I looked some things up and decided to changed the starter solenoid. Tried it out, same thing again. Now I was thinking the battery must be bad so I went and bought a 1000 amp cranking battery. With that many cranking amps i figured I shouldnt have any problems. Got home hooked it up plugged in the charger and waited for all the batteries to finish charging. I tried to crank it in the yard and it acted the same way. The starter starts cranking and then it slows down like the battery is dead in about 2 seconds. Does anyone have any ideas of why it is acting this way? Is there something that is bad that would keep the starter from getting enough voltage?
