Randal McSandal
- May 21, 2013
- 11
I've read in the stickies and done some searching on compression tests, I know that the ignition needs to be disabled during this.
I plan on warming the engine up, pulling the plugs & taking them out of the wires, then attaching the gauge to each cylinder and cranking it with the key, but how do I ground the coil/distributor wire? I'd like to not goof anything up!
Sorry to request a step by step but I'm not clear on the disabling of the ignition.
Boat is an 84 searay seville.
Thanks in advance!
Thanks in advance!
