Switch identification on 1998 Rendezvous
GAC112
I have a 1998 Bayliner Rendezvous. The switch panel is scrubbed clean such that I can't identify the switch functions. I have found most of them by trial and error, however I have three I can't id.
Anyone have one of these that can help? Thanks.
Re: Switch identification on 1998 Rendezvous
A photo might help.
Also, how many switches are there? Which ones have you figured out already? Are the remaining ones 2 position or 3 position?
GAC112
Thanks for the reply. I don't have access to the boat and won't for a couple of weeks. Will post more info then.
Don S
Chances are good that no one has the same boat and can tell you for sure. Below is a wiring diagram for a 22'Cierra. No the same as what you have, but it does show the wire color codes used by Bayliner in 98.
Just look at the back of the switch and see what goes to what.
It's also pretty easy to turn it on and see what comes on and goes off as you flip the switches.
