Re: Mercruiser 5.0 Prop Reccomendation
The Tahoe is a "package" boat that comes from Tracker Marine all set up, including a prop already on it.
Since this is not their first rodeo, they are pretty good at equipping the boat with the correct "general purpose" prop, meaning the one that lets the motor operate within it's recommended rpm range(in this case 4600-5000), while allowing the most top speed, since that's what most folks are interested in.
While the Mercury prop selector says a 19 pitch for this boat, I wouldn't be surprised to see a 21 on there, for the reason mentioned. It would allow for the most speed with a light load.
Until you tell us what WOT rpm this prop does(as well as the prop size) we cannot say whether or not it might be appropriate for whatever your intended use is.
If the boat is "new", you should take prop selection up with your selling dealer, who should be happy to swap out a different prop if a test determines it appropriate for what you are trying to accomplish.
