metriccrescentwrench
- Oct 22, 2007
- 2,598
Depending on loading and conditions my boat tops out at around 65 mph, so I've got an 80 mph speedometer in it. I spend a lot of time pulling my son on a wakeboard or skis, and I'm sure I'll be hounded into pulling a tube this summer also. The problem is that with the 80 mph speedometer I just about need a magnifying glass to read the speed when we're doing watersports because the low end of the dial is so compressed, so it's a real struggle to give anyone a good steady speed.
I'm very close to deciding to put in a 60 mph speedometer just so I can get more resolution at the low end of the range, and when I'm hauling butt not worry about the speed and just be satisfied that we're going fast. I'm a little worried about that though - I know that most industrial pressure gauges can typically handle a small amount of overpressure before they're damaged. Does anyone know if that holds for boat speedometers as well (since they're really nothing but a pressure gauge with a dial marked in mph).
