Dinghy weight
Sachmo
I am looking at a SeaRay 2008 47 sedan bridge. My only concern is will a 500 lb dinghy allow the boat to get up to speed? Will there be any problem getting up on plane?
Sea Rider
Re: Dinghy weight
Welcome to the forums,
Are you going to hung it onboard or tow it behind Sea Ray ? Is it a sib or rib ? Which size & engine is it to weight 500 Lbs.
Happy Boating
Sachmo
Re: Dinghy weight
The dinghy is rigid and weighs 550 lbs wet. It will sit on a hydraulic lift that is on the 47 sedan bridge.
Sea Rider
Re: Dinghy weight
Is that a 47 footer ? Is the hidraulic lift located fore, middle or aft ?
Happy Boating
Sachmo
Re: Dinghy weight
2008. 47 foot sedan bridge sea ray. The hydraulic lift is aft. Swim platform. It holds 800 lbs according to specs my dinghy is 550 lbs wet and is rigid. Just tring to find out about performance.
