catfish9960
- May 22, 2013
- 4
85 evinrude that was running fine, then one day stop pumping water going up the lake..( notice it and shut down before it got hot)...so put a water pump in it and now pumps water at idle and and pees good, but once you give it gas, then it stops peeing and then starts heating up...water will kinda spit out the exhaust port...have not let it got hott..i have shut it down once it does this...if you idle it bacl down then it will start peeing again
