Re: what could be leaking aroung the shift shaft on 85 3.0 mercruiser
are they expensive fixes?
cause I'm not gonna work on it.
any reputable shop will pressure test the complete drive, locate the exact source of the leak and most likely sell you a complete reseal of either the upper or lower depending on where the leaking seal is located
if the history of the drive is unknown a complete water pump replacement is in order too
as far as price, depends on the shop's labor rate and estimate - figure 4-8 hours labor plus parts depending on how far they go
